PanchoB
Aug 05, 2021Follower
Ring devices not connecting to closest satellite
I have an Orbi mesh RBK753S. I have installed 2 Ring outdoor stick up cams, and one ring floodlight/cam. They are all hardwired/plugged in. At first they connected to the closest satellite, and worked...
Aug 06, 2021Guru - Experienced User
Try turning down the power output of the RBRs wifi radios from 100% to 50% and see if this changes anything then reboot the RBR. Under Advanced Tab/Advanced Settings/Wireless Settings
PanchoB wrote:
I have an Orbi mesh RBK753S. I have installed 2 Ring outdoor stick up cams, and one ring floodlight/cam. They are all hardwired/plugged in. At first they connected to the closest satellite, and worked great. Now they connect to the router only, and the connection is terrible. How do I get them to connect to the satellite that is 20 feet away, versus the router that is 60 plus feet away with many walls in between?
