dtay
Jul 15, 2020Luminary
Ring Doorbell Pro shows connected via a wired connection?
I noticed in the Netgear Orbi app as well as via the GUI interface via the web browser, it's reporting that my Ring Doorbell Pro is connected to my Orbi RBK853 as a "wired" connection, when in reality...
- Jul 16, 2020
FURRYe38 wrote:What Firmware version is currently loaded?
Is your RBS ethernet connected to the RBR? If it is and the door bell is connected to the RBS, it will report a wired connection instead of a wireless.
Firmware is V3.2.15.25_1.3.15.
The satellites are connected via Ethernet wired backhaul.
Jul 16, 2020Guru - Experienced User
is the doorbell connected to a satellite? Mine shows my devices connected to the satellites as wired. but if you log into the satellite, it shows wireless on its connected devices page.
- dtayJul 16, 2020Luminary
plemans wrote:is the doorbell connected to a satellite? Mine shows my devices connected to the satellites as wired. but if you log into the satellite, it shows wireless on its connected devices page.
I believe it was connected to a satellite when it was erroneously identiied as connected via wired. Right now, it's showing as connected back to the main router (had to reboot the satellites last night to rearrange the power cables) and it is identified correctly as a wireless connection. Interestingly, I also have a Ring Indoor Cam that is connected to a satellite and the Orbi is identifying it correctly as connected via wireless.
