toror5
Aug 06, 2023Follower
Ring won’t connect
Having issues with my Ring doorbell and I suspect it has to do with the Orbi router. Is it possible the device is blocked and hidden? When I try to setup the ring doorbell it recognizes the SSID but won’t connect to the internet. I’ve tried logging into to the router on a PC but I don’t see it. For some reason Ring won’t pickup the internet even though it finds the SSID. I’ve even tried charging the password on the router but no luck
What Orbi model system do you have?
What modem/gateway is the orbi connected to?
