json2001's avatar
json2001
Risk in disabling DHCP?
I'm considering logging turning DHCP off on my Orbi (RBR850) and turning DHCP server on my piHole already running on my network.   Before doing this, I'm curious - if my pihole fails or goes offlin...
  • FURRYe38's avatar
    Sep 12, 2020
    Yes you should be able too. Or at 192.168.1.1, you might have to set a static IP address on a wired PC to 192.168.1.49 as well until DHCP services are returned to operations.
