snakeking2
Sep 04, 2020Aspirant
robi 753 router in AP mode connected to a GBE switch
this seems like a supported method - modem router to a GBE switch and the Orbi conected to one of hte ports of the Gbe switch. used on this manner the speedtest function within the orbi app does ...
Sep 04, 2020Guru - Experienced User
What modem/gateway are you using?
What switch are you using?
Is your orbi the RBk753?
How exactly is it wired:
for example: modem model*---->switch----->router?
snakeking2
Thank you!
So the topology is xfinity arris 1862L modem router connected to a 16 port TrendNet unmanaged Gbe switch. That switch is connected to rj45s thru out the house and the Orbi753 router is connected to the switch in the study.
- MstrbigSep 04, 2020Master
snakeking2 wrote:
Thank you!
So the topology is xfinity arris 1862L modem router connected to a 16 port TrendNet unmanaged Gbe switch. That switch is connected to rj45s thru out the house and the Orbi753 router is connected to the switch in the study.Sometimes having a switch between the ISP modem and Orbi causes issues. You are better off connecting the orbi directly to your Arris modem/router, then the switch. Then if you have satellites you can connect them to the switch.
- plemansSep 05, 2020Guru - Experienced User
I'd agree with what Mstrbig says and going
modem/gateway-----orbi router---switch---satellites.
I've done it both ways. (modem/router----switch----orbi router)
Satellites
the only time I've found that everything works fine is if the satellites are all wireless. If they're not, then you need the switch after the orbi router for the app/connected devices lists to function properly
- FURRYe38Sep 05, 2020Guru - Experienced User
Be sure to post over in the Orbi AX Forum for you future needs:
https://community.netgear.com/t5/Orbi-AX/bd-p/en-home-orbi-ax
