fxp
Oct 31, 2020Aspirant
Roborock S5 (2.4 GHZ only) network configuration fails
My setup: Motorola MB8600 DOCSIS 3.1 cable modem, Orbi RBR750 WiFi router w/V3.2.16.6_1.4.4 firmware and RBS750 satellite, 1 Gig service from Xfinity. The router and satellite are > 30 feet apart. ...
Nov 01, 2020Guru - Experienced User
You can try turning down the 5Ghz wifi power output on the RBR. Under Advanced Tab/Advanced Settings/Wireless Settings. I would turn OFF the RBS while your trying to get the devices connected.
Disable AX mode on 2.4Ghz.
Try setting CTS to 2347 under Advanced Tab/Advanced Settings/Wireless Settings.
Be sure to get your setup mobile device to connect to the 2.4Ghz signal by turning off it's wifi radio for 5 seconds, then walk out at a distance from the RBR so it won't reconnect to the 5Ghz. Then try to get the 2.4Ghz devices connected...as this is a limitation of the IoT setup software.
