Parth_Goyal
Oct 05, 2020Aspirant
Router Compatibility with ISP
I have fiber optic coming from my ISP which is connected to ISPs router(i.e. modem **bleep** router). I’m looking forward to configure the ISPs router in bridge mode and connect ISPs router to my rout...
- Oct 07, 2020
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
https://kb.netgear.com/26765/Disabled-Features-on-the-Router-when-set-to-AP-ModeIF the ISP modem has a DMZ, try option #2 with the modem and RBR.
Parth_Goyal wrote:Yes, in order to connect to Internet services from ISP's side. I have to login with the username and password provided by the ISP for my account.
I'm from India and my ISP is Tata Sky Broadband. The modem **bleep** router by ISP is Nokia G-140W-F.
Mstrbig
Oct 06, 2020Master
Parth_Goyal wrote:
I have fiber optic coming from my ISP which is connected to ISPs router(i.e. modem **bleep** router). I’m looking forward to configure the ISPs router in bridge mode and connect ISPs router to my router via Ethernet Cable in which I will enter the username and password for WAN(as provided by the ISP).
So, is it that router needs to have some specifications to be compatible with the ISP or configuring the username/password or something? Or all routers support configuring ISPs username password and are compatible with all ISPs.
In my case I’m creating an extensive network in which I intend to use Orbi AX series Mesh WiFi System while in my country(India) Netgear directly sells Orbi AC series only.
So are you saying you have to login to your ISP in order for it to work? Or are your username and password for accessing your ISP router?
Can you share your ISP company and modem/router combo?
- Parth_GoyalOct 06, 2020Aspirant
- MstrbigOct 07, 2020Master
After reading the manual it appears you are going to a specific web page to login. If this is the case, then your Orbi router can be set to router mode. You can leave the Nokia set the way it is and have a double NAT, which only sometimes causes issues with gaming consoles not setup properly and a couple other items. We have dozens of systems running double NAT with no issues.
Or you can configure the Nokia to bridge mode and turn off DHCP and WIFI.
- Parth_GoyalOct 07, 2020Aspirant
Apologies If I ask something noob. But, if I'm not wrong NAT is Network Address Translation and dual NAT can cause conflict sometimes. To overcome that I intend to use the ISP provided router as a modem only by configuring it in Bridge mode. While Orbi router could be used as the primary router.
Am I right about it?
- FURRYe38Oct 07, 2020Guru - Experienced User
Couple of options,
