Parth_Goyal
Oct 05, 2020Aspirant
Router Compatibility with ISP
I have fiber optic coming from my ISP which is connected to ISPs router(i.e. modem **bleep** router). I’m looking forward to configure the ISPs router in bridge mode and connect ISPs router to my rout...
- Oct 07, 2020
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
https://kb.netgear.com/26765/Disabled-Features-on-the-Router-when-set-to-AP-ModeIF the ISP modem has a DMZ, try option #2 with the modem and RBR.
Parth_Goyal wrote:Yes, in order to connect to Internet services from ISP's side. I have to login with the username and password provided by the ISP for my account.
I'm from India and my ISP is Tata Sky Broadband. The modem **bleep** router by ISP is Nokia G-140W-F.
Parth_Goyal
Oct 06, 2020Aspirant
Mstrbig
Oct 07, 2020Master
After reading the manual it appears you are going to a specific web page to login. If this is the case, then your Orbi router can be set to router mode. You can leave the Nokia set the way it is and have a double NAT, which only sometimes causes issues with gaming consoles not setup properly and a couple other items. We have dozens of systems running double NAT with no issues.
Or you can configure the Nokia to bridge mode and turn off DHCP and WIFI.
- Parth_GoyalOct 07, 2020Aspirant
Apologies If I ask something noob. But, if I'm not wrong NAT is Network Address Translation and dual NAT can cause conflict sometimes. To overcome that I intend to use the ISP provided router as a modem only by configuring it in Bridge mode. While Orbi router could be used as the primary router.
Am I right about it?
- MstrbigOct 07, 2020Master
Parth_Goyal wrote:Apologies If I ask something noob. But, if I'm not wrong NAT is Network Address Translation and dual NAT can cause conflict sometimes. To overcome that I intend to use the ISP provided router as a modem only by configuring it in Bridge mode. While Orbi router could be used as the primary router.
You are right and not right depending. There is some truth and untruth. It really depends on the setup and the purpose of the network. You will read the negatives of some that don't quite understand the entire use of double NAT, but you will also read about configurations where it works.
Double Network Address Translation (Double NAT) does not affect Wi-Fi performance. But it can be an issue if you play online games or use port forwarding rules and Universal Plug and Play (UPnP). However there are configuration work arounds for those situations.
We have scenarios where one network connection is coming into a building, and several separately configured networks are working off that one network with absolutely no issues. Some homeowners prefer having 2 different networks, where one feeds off the other creating a Double NAT. They'll run their gaming consoles, cameras, etc. off the primary, through the ISP modem/router and all their PCs, laptops, smart speakers, TVs, etc off their Orbi system. You can have multiple Orbi systems (router and satellites) running in the same building, off the ISP modem/router with no issues if configured properly.
But with all that said, the norm is either ISP router bridge mode, Orbi router mode or ISP router to Orni in AP mode.
