Parth_Goyal
Oct 05, 2020Aspirant
Router Compatibility with ISP
I have fiber optic coming from my ISP which is connected to ISPs router(i.e. modem **bleep** router). I’m looking forward to configure the ISPs router in bridge mode and connect ISPs router to my rout...
- Oct 07, 2020
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
https://kb.netgear.com/26765/Disabled-Features-on-the-Router-when-set-to-AP-ModeIF the ISP modem has a DMZ, try option #2 with the modem and RBR.
Parth_Goyal wrote:Yes, in order to connect to Internet services from ISP's side. I have to login with the username and password provided by the ISP for my account.
I'm from India and my ISP is Tata Sky Broadband. The modem **bleep** router by ISP is Nokia G-140W-F.
Parth_Goyal
Oct 06, 2020Aspirant
Oct 07, 2020Guru - Experienced User
Couple of options,
