diamondscar
Jul 09, 2022Star
Router continually reassigning IP addresses to the satellites.
I'm also having this issue.
Jul 09, 2022Guru - Experienced User
Please edit out any MAC addresses or product serial numbers before posting in public forums for security reasons.
How are your RBS connected to the RBR, wireless or wired?
How many RBS do you have connected?
Is Armor, SPC, or Traffic Meter enabled?
- diamondscarJul 09, 2022Star
Firmware version is V4.6.8.5_2.1.9
Home size ~6500 Sqft
Traffic meter enabled, no limiting
FIOS ONT
1 RBR850 + 1 RBS850 connected via wired backhaul.
- FURRYe38Jul 09, 2022Guru - Experienced User
Is the RBS directly connected to the back of the RBR or is there any LAN patch panel and LAN switch in between?
What CAT# cable are you using between the RBR and RBS? CAT6 is recommended.
Have you set up an IP address reservation for the RBS ON the RBR?
Two switches in between, both showing 1 gbps connection with lights, confirmed with speed tests getting ~900mbps download/upload. Cat 6/7 used with all connections.
**Oops. Yes, RBS is set to 192.168.1.2 and maintains that reservation.
