diamondscar
Jul 09, 2022Star
Router continually reassigning IP addresses to the satellites.
I'm also having this issue.
diamondscar
Jul 09, 2022Star
Firmware version is V4.6.8.5_2.1.9
Home size ~6500 Sqft
Traffic meter enabled, no limiting
FIOS ONT
1 RBR850 + 1 RBS850 connected via wired backhaul.
Jul 09, 2022Guru - Experienced User
Is the RBS directly connected to the back of the RBR or is there any LAN patch panel and LAN switch in between?
What CAT# cable are you using between the RBR and RBS? CAT6 is recommended.
Have you set up an IP address reservation for the RBS ON the RBR?
- diamondscarJul 09, 2022Star
Two switches in between, both showing 1 gbps connection with lights, confirmed with speed tests getting ~900mbps download/upload. Cat 6/7 used with all connections.
**Oops. Yes, RBS is set to 192.168.1.2 and maintains that reservation.
- FURRYe38Jul 09, 2022Guru - Experienced User
What is the Mfr and model# of the ethernet switch in the configuration?
Other than duplicate IP address assignments, is the system working ok?
Both are Netgear. One is a dumb switch, the other is ProSafe. The IP reassignments seem to correlate with wireless devices getting dumped off the RBS and not being able to reconnect for a while. But not all devices and never the wired devices.
