diamondscar
Jul 09, 2022Star
Router continually reassigning IP addresses to the satellites.
I'm also having this issue.
Jul 09, 2022Guru - Experienced User
What is the Mfr and model# of the ethernet switch in the configuration?
Other than duplicate IP address assignments, is the system working ok?
diamondscar
Jul 09, 2022Star
Both are Netgear. One is a dumb switch, the other is ProSafe. The IP reassignments seem to correlate with wireless devices getting dumped off the RBS and not being able to reconnect for a while. But not all devices and never the wired devices.
- FURRYe38Jul 09, 2022Guru - Experienced User
What is the model# of the ethernet switch in the configuration?
What is the distance between the router and 📡 satellite(s)?
What is the current CTS value seen on the RBR? Under Advanced Tab/Advanced Settings/Wireless Settings
Try lowering the transmit power on the RBR from 100% to 50%. Under Advanced Tab/Advanced Settings/Wireless Settings
- diamondscarJul 09, 2022Star
Distance between them is probably 30+ feet. RBR is in the basement and RBS is on the 3rd floor. CTS is 64. Is it possible to lower the power on the RBR alone and not affect the RBS? I have a few places in my house that don't have great coverage already.
Try it can see. You can always put it back.
Seems like devices maybe ping ponging back and forth thus causing these IP addresses. Its up to wifi devices to pick and choose where they connect to and maybe hopping around trying to get connected to one signal source.Basement is not recommended location for the RBR. Even if the RBS are ethernet connected.
