AlphaCat
Feb 20, 2022Guide
Router crashing every 4-5 days (solid magenta error) [RBK852]
About 2 months ago I purchased the RBK852 Orbi (router and satellite) new, and since then the solid magenta error has been happening about once a week, sometimes twice. Each time, there was no unusu...
- Feb 20, 2022
has this been happening since day 1?
There's a newer firmware that's been released to the forum if you want to try it.
New - RBR850 / RBS850 Firmware Version v4.6.7.5 Re... - NETGEAR Communities
Also, there's been reports of memory creep on the 7 and 8 series that's being worked on.
How many devices do you have connected?
Feb 21, 2022Guru - Experienced User
AlphaCat wrote:
About 2 months ago I purchased the RBK852 Orbi (router and satellite) new, and since then the solid magenta error has been happening about once a week, sometimes twice. Each time, there was no unusual traffic or streaming load occurring. The satellite is also not too far from the router. Both are running the latest firmware (v 4.6.3.16)
Each time it loses connection I've just been unplugging the router and plugging it back in. Oh, and the router is plugged directly into the ISP service box with a 1-meter long ethernet cable, and the unit is out in the open (i.e., not put in an poorly ventilated space).
Anyone know if there's a fix of some kind that can stop this from happening so often? FWIW, the ISP-provided router that the Orbi replaced only crashed once in 2 years.
AlphaCat
Feb 21, 2022Guide
I'm in Australia and have a FTTH connection, so the ONT is the one provided by NBN (the government's monopoly operator). It's just a white box with no obvious branding or model info.
I updated the firmware 2 days ago and so far so good. I'll post again if the error happens.
