Ven2020
Sep 30, 2021Guide
Router Login Issues
I have RBR850 router mesh system with four RBS850 satellites. Firmware version is upto date. I am unable to login to the router either on the web login or Orbi app on my mobile. I tried orbilogin.net...
Sep 30, 2021Guru - Experienced User
What browser are you using? Happens on MS Edge, Firefox or Opera as well after a few days?
When your resetting and setting up from scratch are you using Orbi app or a wired PC and web browser pointed at the RBR web page to set up the system?
Ven2020
Sep 30, 2021Guide
I have Verizon FIOS and there is a box outside the house. Don't know the make and model of the ONT box but I don't think it has anything to do with my issue. Netgear level 2 support also said that I should be able to login to the router, whether I have internet or not. My internet is working fine.
Coming to resetting the system, I use Orbi app to setup the system. I am not sure it can be done on a wired PC web browser. The setup starts with scanning the QR code (on the router) using mobile device.
I have this issue on Chrome, Microsoft Edge, Firefox and Internet Explorer.
- FURRYe38Sep 30, 2021Guru - Experienced User
What FW version is currently loaded?
Wire connect a PC to the router and factory reset the router using the back push pin button. Hold it in for 15 seconds then let go. Power OFF the ISP modem/ONT for 30 seconds than back on. Wait for the WHITE led to slowly pulsate on top of the RBR, then log in to orbilogin.com using a web browser and walk thru the setup wizard. This time write down all important information for safe keeping later on.
- Ven2020Sep 30, 2021GuideWill try this and post it back here. Could take few days to know if the login issue is resolved.
Another suggestion would be to manually download the FW files again to the RBS then RBR using a wired PC and web browser, reset and setup from scratch then see what happens.
