Ven2020
Sep 30, 2021Guide
Router Login Issues
I have RBR850 router mesh system with four RBS850 satellites. Firmware version is upto date. I am unable to login to the router either on the web login or Orbi app on my mobile. I tried orbilogin.net...
Ven2020
Sep 30, 2021Guide
That is what I did but it did not fix the problem
Sean_Orbi_dude
Oct 23, 2021Aspirant
I have the exact same issue.
Devices:
RBR850/RBS850 (single satellite) Latest firmware version 4.6.3.16
iOS
Windows 10
Restart router --> can login to router admin page on default IP address --> (I timed this) 3min later --> "loading circle" appears and I cannot continue to login or use the page
Any further attempts to connect to router login page --> Fail (circle of despair noted)
My iphone with the orbi app is still receiving notifications from the router.
But I cannot access the router setup via orbi app on the iphone
Internet access is good. No trouble surfing / watching Netflix.
Pinging default router admin IP - 4 packs sent, 4 received ; no issues.
Things tried:
RMA both router and satellite - no change
Manual firmware update - no change
Power cycle modem + router - no change (my modem does NOT have a built in router)
Varying wired vs wireless computers to connect router - also fail
Setup:
Windows 10 LAN direct cat 5e cabled connection to router
