thnet
Dec 23, 2021Follower
Router must be reset daily.
The model is RBKE963 AXE11000. I have a passthrough set up on my modem to use this as the router for my house. The speed is great for 24 hours after turning on. The next day all devices can still con...
Dec 24, 2021Guru - Experienced User
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡
What channels are you using? Auto? Try Auto and 48 on 5Ghz. Or try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
What devices are you speed testing with? Wired or Wireless? Both?
thnet wrote:
The model is RBKE963 AXE11000. I have a passthrough set up on my modem to use this as the router for my house. The speed is great for 24 hours after turning on. The next day all devices can still connect, but the max speed is aroun 10-50 Mbs (I have gigabit and get ~960 Mbs normally). I can see the speed that the Orbi router is still getting about 960 Mbs, but not passing that to connected devices. This is immediately fixed by rebooting the router. I find this highly annyoing to have to do everyday. I called Netgear support and they offered to fix it for $150 even though I just bought this new product 2 weeks ago.
