JimTurkey
Apr 24, 2023Guide
Router needed?
I have the AX4200 WiFi Mesh System (RBK753) with 2 satellites. I've had U-Verse Fiber for years and now can switch as I move. I'm going with Vyve Broadband, and, as I understand, can supply my own ro...
- Apr 24, 2023
Yes. There can be too much wifi signal flooding a home size. https://youtu.be/UR0viMLISz4
There are configurations that need additional RBS, however for some of these, one can do this and then turn down the power on the system to help with getting good wifi over lap and wifi coverage. I have a 5000sq ft home, 3 levels I can get away with one RBS at 100%. I normally have two online and use 50% or 25% power depending. I get good coverage and over lap.
Apr 24, 2023Guru - Experienced User
Does the Orbi system work? if so, you could migrate it to the new ISP and use it there...
