JimTurkey
Apr 24, 2023Guide
Router needed?
I have the AX4200 WiFi Mesh System (RBK753) with 2 satellites. I've had U-Verse Fiber for years and now can switch as I move. I'm going with Vyve Broadband, and, as I understand, can supply my own ro...
- Apr 24, 2023
Yes. There can be too much wifi signal flooding a home size. https://youtu.be/UR0viMLISz4
There are configurations that need additional RBS, however for some of these, one can do this and then turn down the power on the system to help with getting good wifi over lap and wifi coverage. I have a 5000sq ft home, 3 levels I can get away with one RBS at 100%. I normally have two online and use 50% or 25% power depending. I get good coverage and over lap.
CrimpOn
Apr 24, 2023Guru - Experienced User
JimTurkey wrote:
- Do I need a router? I've always had to use AT&T's in the past and never had to worry about a router.
- What router would you recommend so that things work best?
Yes, every customer needs a router. You already have a router as part of the Orbi RBK753 package. If this is the new Internet Service Provider (ISP) https://vyvebroadband.com , then they appear to offer the eero WiFi product as one of their options (which you do not need unless you want to change - and pay Vyee more money every month).
On the forum terminology is critical. Every customer has to have some device which converts the ISP platform to Ethernet for their internal use. Traditional cable systems (Charter, Cox, Xfinity, etc.) piggyback internet on their cable TV systems, and customers need a cable modem interface. AT&T provides their own box (which your Orbi is connected to). Fiber systems, such as Vyve use an Optical Network Terminator (ONT).
JimTurkey
Apr 24, 2023Guide
Thank you both! Definitely clears things up!
As a follow-up... I currently have the Orbi router + 2 satellites. I will be moving to a new house:
- 2 floors
- 9 total rooms (bedrooms, office, living room, etc)
- 4200 square feet
In addition to the Orbi router, how many satellites would you recommend?
- CrimpOnApr 24, 2023Guru - Experienced User
This depends to a large degree on
- The shape of the building
- Where the ISP service enters the building
- Whether the building is already wired with Ethernet cable
- How much coverage is wanted "outside" the primary building envelope (such as patios, eaves for security cameras, back yards, front porch, etc.)
- FURRYe38Apr 24, 2023Guru - Experienced User
For that size of home, two should be ok. 30 feet or more is recommended in between RBR📡 and RBS🛰️ to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 🛰️
- 2 floors
- 4200 square feet
- JimTurkeyApr 24, 2023GuideIs this something where the fewer satellites, the better?
