JimTurkey
Apr 24, 2023Guide
Router needed?
I have the AX4200 WiFi Mesh System (RBK753) with 2 satellites. I've had U-Verse Fiber for years and now can switch as I move. I'm going with Vyve Broadband, and, as I understand, can supply my own ro...
- Apr 24, 2023
Yes. There can be too much wifi signal flooding a home size. https://youtu.be/UR0viMLISz4
There are configurations that need additional RBS, however for some of these, one can do this and then turn down the power on the system to help with getting good wifi over lap and wifi coverage. I have a 5000sq ft home, 3 levels I can get away with one RBS at 100%. I normally have two online and use 50% or 25% power depending. I get good coverage and over lap.
JimTurkey
Apr 24, 2023Guide
Thank you both! Definitely clears things up!
As a follow-up... I currently have the Orbi router + 2 satellites. I will be moving to a new house:
- 2 floors
- 9 total rooms (bedrooms, office, living room, etc)
- 4200 square feet
In addition to the Orbi router, how many satellites would you recommend?
CrimpOn
Apr 24, 2023Guru - Experienced User
This depends to a large degree on
- The shape of the building
- Where the ISP service enters the building
- Whether the building is already wired with Ethernet cable
- How much coverage is wanted "outside" the primary building envelope (such as patios, eaves for security cameras, back yards, front porch, etc.)
