D50ranch
Mar 29, 2021Aspirant
router rbk32 stopping devices
Hi i havew a rbk53 mesh router system and it recently is starting to Block my devices I go to adm part of router and try to unblock the devices and it doesnt work I have done a refresh rebooted t...
CrimpOn
Apr 01, 2021Guru - Experienced User
D50ranch wrote:Hi i havew a rbk53 mesh router system and it recently is starting to Block my devices I go to adm part of router and try to unblock the devices and it doesnt work
I have done a refresh rebooted the router with no luck
Where on the Orbi admin interface does it show devices "blocked"? Can you attach a screen shot?
- D50ranchApr 02, 2021Aspirant
This is under
advanced
Security
\access control
- CrimpOnApr 02, 2021Guru - Experienced User
"in line" images put into a post using the Photos icon do not appear to other users until approved by a forum moderator, which can take hours (and hours). images attached using the Browse button (lower left) are available immediately.
Is Access Control shows as "on" or "off"?
I believe that nothing can be done to items on the Access Control list until Access Control is "on". My work-around is to enable Access Control, change things around, and then turn it back off.
I keep hoping that someone will figure out my WiFi password and connect to my Orbi, but as the password is 25 characters long, it may take someone about 4 billion years to guess it by brute force. So, I leave access control "off".
