JimWS
Sep 16, 2021Tutor
Router RBR750 not allowing Internet access
I ireceived and nitiated the Orbi RBR750 with sateliite and was working yesterday . This morning no internet - Sparklight vie fiber when running through the router.. When plugging from modem to Apple...
- Sep 16, 2021
What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too?Has a power off for 1 minute then back ON with the ISP modem and Orbi system been performed since last update?
JimWS
Sep 18, 2021Tutor
Firmware
V4.6.3.16_2.0.51 |
Modeim is Nokia and Firber connection with Sparkllight .
Thanks very much for your help. I did as you suggested. Powered all down and up again and restarted .
I am getting better internet access with with my macbook air than my desktop iMac
Also I have less problems with access when I turn off the Norton firewall.
My iphone 12 has intermittent issues with web sites , but my wife has more issues with her iphone 11.
I hvae contacted Norton and will remove Norton from our phones.
I have excllent speeds with my Macbook Air and iMac when I turn off Norton Firewarll . I do not have the Apple firewarll turned on.
Thanks again for you help and response.
JimWS
Sep 18, 2021Tutor
As an addendum the iphone connection with my iPhone 12 and my wife's iphone 11 is much better after deleting the Norton App.
I will contact Norton about this
- FURRYe38Sep 19, 2021Guru - Experienced User
Glad you got it figured out.
Be sure to save off a back up configuration to file for safe keeping. Saves tine if a reset is needed.
https://kb.netgear.com/000062080/How-do-I-back-up-the-configuration-settings-on-my-Orbi-WiFi-SystemEnjoy,
