donawalt
Jan 21, 2024Mentor - Experienced User
Router restart all of a sudden then problems
This is the second time this has happened to me... Config - 1 RBR850, 2 RBS850's. All are on V7.2.6.21_5.0.20 firmware. No VPN, Armor, or Parental Controls activated. Modem is NG 2050V. I have t...
Jan 21, 2024Guru - Experienced User
K, Ya kinda odd. Not sure.
Mark this one down and date and time and then monitor for next one.
MIght check CPU usage and memory usage as well to see you notice any spikes or high usage here. CPU usage could cause this.
donawalt
I will.
I do check the debug stats periodically, they always have looked fine. Hard to nail it when it happens 2 weeks later. I'll keep an eye on it daily or so to see if CPU or memory usage is creeping up.
