donawalt
Jan 21, 2024Mentor - Experienced User
Router restart all of a sudden then problems
This is the second time this has happened to me... Config - 1 RBR850, 2 RBS850's. All are on V7.2.6.21_5.0.20 firmware. No VPN, Armor, or Parental Controls activated. Modem is NG 2050V. I have t...
Jan 23, 2024Guru - Experienced User
Kinda of hard to believe the ISP changes would cause issues at the RBS though.
donawalt
Jan 23, 2024Mentor - Experienced User
True - although the RBR could be instigating it. Even that is a little hard to believe as BullMoon said. I could see the modem causing the router to reboot. But the madness of what happens on soft reboots is all Netgear I think. Like I said at one time in the past, they really need to test/debug the setup/restart etc scenarios, on the forums this is the stuff that causes people problems. Unless you restart everything, or upgrade firmware, etc. in exactly the perfect way, the system has problems. That's not right.
