donawalt
May 03, 2024Hero - Experienced User
Router stopped working for no reason
This morning, I noticed Wifi AND direct Ethernet connections had no internet access from my RBRE960 router. I checked the Xfinity app, it said the modem was online and fine. There was nothing in the ...
May 03, 2024Guru - Experienced User
- FURRYe38May 03, 2024Guru - Experienced User
How many days was it online before this happened this morning? Only thing I can think of is enable debug logging on the RBR at start up and if it happens again, see if you can save off the logs.
- donawaltMay 03, 2024Hero - Experienced User
To answer everyone's questions:
FURRYe38 I submitted a support ticket!
How many days was it online before this happened this morning? 7+
Only thing I can think of is enable debug logging on the RBR at start up and if it happens again, see if you can save off the logs. ---> I couldn't access either the router admin web page or any running lan/wan capture logs when it happened. So that probably won't be useful.
CrimpOn I could not get access to the debug page - I tried that. The network was completely down!
Ok, Ya hoping that NG can figure this out. Should not happen. Only thing I can think of is you've seen odd behaviors since you installed the XS series switch. 🤔
It could also be related to higher speeds - I used to be 1GB now it's 2GB. Probably not a ton of customers running at that speed on Comcast (which they have clearly had challenges with). Also, if they can't/don't test a ton of long-term issues, that would fit in - it ran perfectly for 7+ days.
