RafK1
Jan 18, 2025Tutor
Router won’t connect to verified internet connectio
I am trying to set up an RBR660 router. After connecting to the ISP modem, it keeps saying “no internet connection detected” even though 1) cables are all working properly (tested with other device); ...
- Feb 02, 2025
What happens if you power OFF The RBR and RBS for 1 minute, then back on with the RBR first, then about 30 seconds later, power ON one RBS at a time. Does the RBS connect and show up in the WEB UI? Might bring the RBS to same room as RBR to check this...
Do they appear in Orbi app at all?If they don't, you might disconnect the RBR from the ISP service.
Change the RBR back to 192.168.1.1 and apply the change and let the system reboot. May need to power cycle the RBS as well here. Then give about 10 minutes, check the RBRs web page for RBS. They should appear in the WEB UI. If they do either change the RBR back to 192.168.4.1 or try 192.168.0.1. I've always used .0.1 and everything has worked on this submet.
CrimpOn
Jan 18, 2025Guru - Experienced User
It would really be helpful to know the exact model number of the Calix device.
Reason: Although some devices have more than one Ethernet port, they function correctly only when there is only one device connected at a time. I may not be reading the description correctly, but it appears to me that there are two devices connected to the Calix at the same time.
RafK1
Jan 19, 2025Tutor
Thanks - it’s a Calix T073G-2. ISP tech support told me to use either LAN 2 or LAN 3 for connecting router or direct connection. With my previous setup, I connected the Airport Extreme to LAN 2, and a direct PC to LAN 3 without any issues. When I first tried to install and configure the ORBI, I only had it connected to the router on LAN 2, without any issues nothing else connected. Thanks again for helping me troubleshoot this. My next step will be to review the DNS setting in the AirPort Extreme, as well as assigned dynamic IPs, to see if there’s anything funky in the ISP setup (but based on previous experience, am 99% positive that they just provide a dynamic IP with no additional configuration)
- CrimpOnJan 19, 2025Guru - Experienced User
Thanks for the product number. This is clearly a combination fiber ONT/router/WiFi/phone unit:
https://fccid.io/2ABLK-T073G-2/External-Photos/Ext-2328078
https://fccid.io/2ABLK-T073G-2/User-Manual/User-Guide-2328083.iframe
According to another User Manual I found on line, the Calix will have a LAN address of 192.168.1.1.
It will assign an IP address to every device connected to it in the 192.168.1.x subnet.
When this happens, the Orbi will switch to the IP subnet 10.0.0.1 for devices connected to it.
My next step would be to connect a computer to one of the Ethernet ports on the Orbi and open a web browser to 10.0.0.1
Ignore stupid warning messages about the connection being insecure.
This is a classic "Double NAT" situation, which can interfere with specific network applications. (Internet search for examples.) If one of this situations affects you, then there are several options for dealing with it.
- RafK1Jan 19, 2025TutorThank you for the continued effort to help resolve. I came to the same conclusion as the IP address of my old router (Airport Exrreme) was 192.168.2.1xx, which means the Calix has its own NAT. I contacted my ISP and they suggested that I bring the Orbi into their support center so that they can troubleshoot there. I’m hoping they can show me how to turn off the NAT on the Calix so that I can use the Orbi’s full set of features. Will keep you posted.
- RafK1Jan 19, 2025TutorJust spoke to the ISP. They can issue me a static IP on one of the ports of the Calix, which I can then connect the Orbi to, and configure it with the static IP during setup. Hopefully this will resolve the problem. Thanks again!
- FURRYe38Jan 20, 2025Guru - Experienced User
Wondering if a placement of a 1Gb NON managed switch in between the ONT and the RBR would be helpful. Sometimes ONTs have odd connection and handshaking processes that the RBR doesn't support. Putting in a 5 port 1Gb non managed switch could help here.
