kaosken
Jun 22, 2022Aspirant
RPRE960 Speed test AOK but not Interent acces for any client
My customer has the RBRE960 with 1GB Frontier FIOS service. All current clients have no Internet access. I added my cell to the network in order to test. DHCP AOK, Ping AOK, Speed test @ near 1GB. ...
- Jun 23, 2022
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
Jun 22, 2022Guru - Experienced User
Both wired and wireless devices can't get internet access?
Doe the RBRs web page show GOOD status for Internet access on the Basic tab in a web web browser?
kaosken
I am not on site right now.
ISP is Frontier FIOS. No clue on ONT make model. Doubt an issue as nothing changed for months and Network TV AOK.
Don't have the firmware version. Product has worked flawlessly for 6 month or more.
Neither existing WIFI or Ethernet clients have Internet access.
My own CELL connected as a new client. Speed test @ 1GB up and down.
- kaoskenJun 22, 2022Aspirant
The RBRE960 is connected directly to the ONT.
- FURRYe38Jun 22, 2022Guru - Experienced User
OK. Sounds like something has happened on the system or in between the RBR and ISP services.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡Are the RBS wireless or ethernet connected to the RBR?
What channels are you using? Auto? Try Auto and 48 on 5Ghz. Or try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
Any Wifi Neighbors near by? If so, how many?Is the separate 6Ghz SSID section, Armor or Smart Parental Controls enabled or disabled?
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.A factory reset maybe needed if one hasn't been done since last FW update.
The RBRE IS connected direct to the ONT...no other router or modem. And, the fact that the RBRE does speed test w/o fail tells me that that connection to the ONT is solid.
This is a small house and could run the entire network w/o the 2 satellites.
Unless the ORBI is set to auto update FIRMWARE it has never been reset.
That is what I intend to do when I return.
This problem happened all at once. All clients blocked somehow. Parental controls is OFF.
I'm going to turn of Armor, too. It is a PIA!
This is a weird problem. I've been a tech for 40+ years and pretty much know where to look for issues. But if NG has firmware issues now that is a big problem!
I thank your for you help.
How small of a house?
Ok, I would start simple, turn OFF ALL RBS, Armor and SPC if there enabled. After you disable Armor, power OFF The ONT and RBR for 1 minute then back ON with the ONT first then RBR. Check for internet services.
Lets see what the RBR is doing by itself.
