kaosken
Jun 22, 2022Aspirant
RPRE960 Speed test AOK but not Interent acces for any client
My customer has the RBRE960 with 1GB Frontier FIOS service. All current clients have no Internet access. I added my cell to the network in order to test. DHCP AOK, Ping AOK, Speed test @ near 1GB. ...
- Jun 23, 2022
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
kaosken
Jun 23, 2022Aspirant
Yes. Thanks again for your help. I don't know why I was tentative over doing the reset as I know how to set it all up again. In actuality, it was pretty easy.
Jun 23, 2022Guru - Experienced User
Enjoy. 📡
- TC_in_MontanaJun 23, 2022Virtuoso
If you would - could you please let us know if you have (or had) the following setting enabled?
There have been a couple of other issues with the 960 reported recently and we are trying to identify if this may be something causing the issue. For now, we are just gathering information.
Thanks!
