gk7
Nov 30, 2022Aspirant
run 2 different wifi networks with 1 modem?
I purchased the new Ax6000 RBR850 Orbi + satellites. A couple of my laptops do not seem to want to stay connected or even recognize it consistently, despite updating the network adapter drivers. I...
CrimpOn
Nov 30, 2022Guru - Experienced User
If the ISP device is truly a "modem" (not a combination modem/router/WiFi device), then only one router can be connected directly to the modem. (I suggest the RBR850.)
The RBR50 WAN port can be connected to a RBR850 LAN port with an Ethernet cable. The RBR50 can be placed in access point (AP) mode so that the RBR850 will create one IP subnet that contains all devices. And, yes, the RBR50 WiFi SSID can be anything you want. Devices will not roam seamlessly between the 850 and 50 networks.
Could you please identify the laptops that work with the RBR50 but do not work with the RBR850?
CrimpOn
p.s. If the laptops are really old, sometimes older devices do not get along well when the "ax" feature is enabled on the WiFi system. You might try unchecking that feature temporarily and see if it makes a difference.
- gk7Nov 30, 2022Aspirant
Thanks. I might do that. I want to take advantage of full features for the devices that are working well. One of the laptops is getting replaced soon, but 2 are work provided laptops so not completely in control. One is an Asus gaming laptop that is old (~ 4 years). We uninstalled the network adapter and reinstalled and it works for a while but then disconnects and have to go through process again to see the new network. My work laptop is a Dell Latitude 7490 and am trying to get an upgrade. It connects but periodically disconnects and reconnects; complicated by VPN so have to continually disconnect and reconnect for my outlook and teams to stay connected. My husband’s work laptop won’t even see it and since no admin rights hasn’t gotten drivers updated yet.
- CrimpOnNov 30, 2022Guru - Experienced User
If the ax feature is disabled, the new Orbi RBR850 WiFi should be identical to the RBR50 WiFi. If it "saw" the Orbi before, it should see it now. By "see" means the Orbi WiFi appears on the list of available WiFi networks? i.e. the problem is that the Orbi WiFi does not even show up to be selected?
- FURRYe38Nov 30, 2022Guru - Experienced User
YOu can run two Orbis. However I would recommend keeping the SSIDs Different from the other.
I have done this as a couple of my modems and ISP allow for having two or more routers running at the same time while in router mode. Not all ISPs or modems allow this.
You can run a router behind another router as well, just be sure to use the 1st routers DMZ for the 2nd router running behind it to help avoid double NAT issues. I've done this as well.
Also be sure to use far appart channels on each system. So main system keep it at channel 1 and 40, the other system, keep it at 11 and 48. Separate and different SSID names is recommended.
