gk7
Nov 30, 2022Aspirant
run 2 different wifi networks with 1 modem?
I purchased the new Ax6000 RBR850 Orbi + satellites. A couple of my laptops do not seem to want to stay connected or even recognize it consistently, despite updating the network adapter drivers. I...
gk7
Thanks! Tried connecting them but didn’t put in AP mode so didn’t work.
CrimpOn
Nov 30, 2022Guru - Experienced User
AP mode accomplishes one specific task: creating one IP subnet so that all devices appear in one subnet and can "see" each other. For example, if a printer is connected to the new RBR850 network (to any router or satellite), it will get an IP address from the 850. Here is how router vs. AP mode differs:
- In router mode, the RBR50 will create a different IP subnet for all devices connected to it. If the RBR850 has created subnet 192.168.1.x, then the RBR50 will create subnet 10.0.0.x A laptop connected to the RBR50 can access the internet just fine. It can run VPN software to connect to corporate just fine. What it cannot do is access that printer.
If those laptops connect to the RBR50, then they should work. If they do not connect at all, there is something else wrong. - In Access Point (AP) mode, the RBR50 does not create a new subnet. The RBR850 router continues to assign IP addresses to every device in its network, usually 192.168.1.x Every device connected to either the 850 or the 50 appears in one subnet. Laptops can print to the printer no matter which unit they are connected to.
I have successfully connected three routers in a row, and devices connected to that third router access the internet just fine. The problem is when the user wants to use specific applications, such as using VPN into the home network, exposing servers to the internet, certain internet gaming, etc.
