paulgraham
Sep 04, 2023Aspirant
Running a R8000 and Orbi RBR850 mesh set-up
Hi folks .. just looking for some advice. I have fibre and run a Nighthawk R8000 and Orbi RBR850 set-up and curious to hear what config I should best use.... it all performs pretty well other than I ...
Sep 05, 2023Guru - Experienced User
If it works, don't fix it.
paulgraham
Sep 05, 2023Aspirant
Having to add a manual DNS entry doesn't quite 'work' they way I thought this might
