paulgraham
Sep 04, 2023Aspirant
Running a R8000 and Orbi RBR850 mesh set-up
Hi folks .. just looking for some advice. I have fibre and run a Nighthawk R8000 and Orbi RBR850 set-up and curious to hear what config I should best use.... it all performs pretty well other than I ...
Sep 05, 2023Guru - Experienced User
Yes. NG routers act as a DNS Proxy by relaying DNS from clients out to the detected ISP DNS or any custom DNS configured ON the router.
paulgraham
Sep 05, 2023Aspirant
OK - thanks, so no need for me to manually change the clients if they have the NG IP address? just odd that it makes a difference on a Windows machine
- FURRYe38Sep 06, 2023Guru - Experienced User
Correct, all DNS flows thru the DNS proxy on the router. NG has never been known to offer a DNS option for this. Other router mfrs do like D-Link.
What is the difference your seeing on this Windows PC?
- paulgrahamSep 16, 2023Aspirant
Typically a DNS error / address not found error - then a just refresh a couple of times and it then works OK. If I manually set the Windows 11 IP DNS entry to 8.8.8.8 then it works fine each time. Works great for the Mac and Linux clients, but not windows.
- FURRYe38Sep 16, 2023Guru - Experienced User
Try enableing IPv6 and set it to AUTO on the R8000 router.
There is known issues with DNS on this model router.
