Craigmcgowan
Jan 14, 2021Follower
Samknows Test not working on RBK853
Around two weeks ago I installed a virgin media 1gb connection with the relatively new Virgin Media Hub 4. When the Hub 4 was in modem/router mode I was able to complete a real test on samknows. I...
Jan 15, 2021Guru - Experienced User
Be sure to check your CTS values. If they are at 64, change both to 2347. Reboot both RBR and wireless devices. Under Advanced Tab/Advanced Settings/Wireless Settings
Disable AX mode and test.
Check with the Mfr of your device for additional help and information regarding compatibility with Orbi AX.
