Craigmcgowan
Jan 14, 2021Follower
Samknows Test not working on RBK853
Around two weeks ago I installed a virgin media 1gb connection with the relatively new Virgin Media Hub 4. When the Hub 4 was in modem/router mode I was able to complete a real test on samknows. I...
schumaku
Jan 15, 2021Guru - Experienced User
Simple: There is a SDK (closed source - binary code!*) to be implemented on the router - which isn't there, so it can not detect my samknows compatible device.
Get a so called "Whitebox" Agents | SamKnows if you intend to participate.
*not acceptable in my opinion. Or did you know the Linksys Velop AX5400 has something the like in place?
