Yasou
Sep 20, 2023Aspirant
Samsung cellphone A32, A72, and Galaxy tab A7 lose connection to RBR850 /RBS850
My above Samsung cellphones and tablet, and my IPhone 7 Plus, lose connection to my Orbi WiFi network. This has been happening for the last 2 weeks. It’s a daily problem, and about every 2nd day with...
- Oct 02, 2023
Ya totaly agree. BOTH mfrs were not better forthcoming when they intro'd this feature. Seems to have weaseled it's way in there OS updates and after it was loaded, was kind of glanced over by everyone until other users started posting about it and meantioning they tried disabling it and solved there problems.
So ya, if your at home with phones and pads, leave it disabled. Out side from home traveling, yes, enable it as it is a security and privacy risk when at foriegn wifi signals with or with out security set.
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
Sep 20, 2023Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended
How many RBS are deployed?
What is the distance between the router and 📡 satellite(s)? 30 feet or more is recommended in between RBR📡 and RBS🛰️ to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 🛰️
Does this happen with the RBS turned OFF?
Does this happen with both wireless and wired devices?
What channel configurations are currently set on the router?
Be sure to disable any MAC Address randomizers on phones and pads while at home:
https://community.netgear.com/t5/Orbi-App/NETGEAR-Mobile-Applications-and-Apple-Devices-FAQ/td-p/2220016/jump-to/first-unread-message
Armor, Smart Parental Controls or Circle, Traffic Meter.
Yasou
Oct 01, 2023Aspirant
Thanks for the detailed points!😃. After going thru all your suggestions, I found the problem. It was the MAC address randomizing which was turned on on the various cellphones. Never heard of such a feature. Why was this ever turned on without any warning by the manufacturers? It’s not a security issue. It’s about privacy. From what I can gather, it should be a feature that is turned off when in home WiFi and then on when at the local coffee shop. Am I missing something? Thanks again for guiding me to the solution. Much appreciated.
