Davidrouteracc
Sep 29, 2022Aspirant
Samsung TV cant join Orbi Wifi
Orbi RBR750, 2 satellites (1 of them inches away from the TV) Firmware V4.6.9.11_2.3.5 While I did see other posts about this, they seem to be over 1 year old... The Samsung TV can join oth...
- Sep 30, 2022
I was finally able to connect.
Used the normal password with special characters, connecting to the satellite.
After I setup the static IP and configured it, I got the same error. I left the room and forgot to write down the error message. I returned and setup the same static IP and worked this time!
I restarted the TV a bunch of times, rescanned the wifi etc and seem to stay on and work with the static IP.
Sep 29, 2022Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡
Turn OFF the RBS temporarily and see if the TV will connect to the RBR...
What channels are you using? Auto? Try Auto and 48 on 5Ghz. Or try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
What security mode is set on the RBR? WPA2 and AES is recommended.
Contact the TV mfr for help and support information regarding there product.
- DavidrouteraccSep 29, 2022Aspirant
Please note I previously used a Netgear Nighthawk router on the TV hasnt had a single issue for years.
Xfinity, Motorola MB7621.
About 25 feet from the Router to the Satellite. Attached Devices Backhaul Status shows Good.
A couple(2) of other devices in the same room farther away from satellite the than the TV connect with no issues.
I have tried to move the satellite closer and farther and it still couldnt connect.
channels are on Auto and 5Ghz was on 48. Wifi channel scanner showed 4 with the least ussed.I have tried disabling the ax mode for both.
yes using WPA2 and AES.
I will try to unplug the satellite and connect to the router tonight.
Thanks
