Davidrouteracc's avatar
Sep 29, 2022
Samsung TV cant join Orbi Wifi
Orbi RBR750, 2 satellites (1 of them inches away from the TV)  Firmware V4.6.9.11_2.3.5   While I did see other posts about this, they seem to be over 1 year old...   The Samsung TV can join oth...
  • Davidrouteracc's avatar
    Davidrouteracc
    Sep 30, 2022
    Thanks FURRYe38  CrimpOn
    I was finally able to connect.
    Used the normal password with special characters, connecting to the satellite.
    After I setup the static IP and configured it, I got the same error. I left the room and forgot to write down the error message. I returned and setup the same static IP and worked this time!
    I restarted the TV a bunch of times, rescanned the wifi etc and seem to stay on and work with the static IP.
