Davidrouteracc
Sep 29, 2022Aspirant
Samsung TV cant join Orbi Wifi
Orbi RBR750, 2 satellites (1 of them inches away from the TV) Firmware V4.6.9.11_2.3.5 While I did see other posts about this, they seem to be over 1 year old... The Samsung TV can join oth...
- Sep 30, 2022
I was finally able to connect.
Used the normal password with special characters, connecting to the satellite.
After I setup the static IP and configured it, I got the same error. I left the room and forgot to write down the error message. I returned and setup the same static IP and worked this time!
I restarted the TV a bunch of times, rescanned the wifi etc and seem to stay on and work with the static IP.
Sep 30, 2022Guru - Experienced User
Just curious, if you temporarily disable or turn OFF WPA security, set to NONE, Does the TV connect then?
Re-enable WPA after testing this.
Davidrouteracc
Sep 30, 2022Aspirant
- FURRYe38Sep 30, 2022Guru - Experienced User
So you set a static IP address ON the TV?
- DavidrouteraccSep 30, 2022Aspirant
yes static on the TV and reservation on the router.
What happens if you remove the Reservation from the router for the TV? Normally you either set a static IP address ON devices or Reserver IP address for devices ON the router. Not both.
