2dogs81
Mar 23, 2025Aspirant
Samsung Tv does not connect to orbi RB850
Hi Brains trust, I set up my new ORBI Mesh router and satellite RB850 last night and I have not been able to connect my Samsung Tv to the Orbi. I see that there is lots of similar comments...
CrimpOn
Mar 23, 2025Guru - Experienced User
Orbi 'mode' has no bearing on WiFi connections. ('router' or 'access point' (AP) WiFi devices connect the same way.)
- Do any other WiFi devices have difficulty connecting? (This Samsung TV is the only device that will not connect?)
- Are there any unusual characters in either the WiFi name (SSID) or password?
- How is the Orbi system configured in terms of satellites connecting to the router? (using the default WiFi connection? or with satellites 'wired' to the router?)
- If 'wired' how are the units connected? (all to the Telstra? any switches involved?)
- 2dogs81Mar 23, 2025Aspirant
No other device has had issue connecting to the Orbi just the samsung tv.
No unusual characters in SSID or password
Satellite is WIFI connection and I have tried turning the satellite off.
No switches are involved.
- CrimpOnMar 23, 2025Guru - Experienced User
Which specific model of Samsung TV?
(presume the TV was working correctly with the previous WiFi system? When I replace WiFi systems, I always use exactly the same WiFi credentials on the new system (SSID/password). Not interested in reconnecting 40+ WiFi gizmos. With the same credentials, they 'just connect'.)
Yes it was working perfectly prior to setting up the Orbi system.
Its a UA65KS9000W
