MK2022
Feb 01, 2022Aspirant
Samsung TV [KS7000] can't connect to WIFI [ORBI RBK 752 - 2 pack mesh]
Last Saturday, purchased and installed ORBI RBK 752 2-pack mesh system. My Samsung TV KS7000 can't connect to the ORBI WIFI ['Wireless network disconnected. IP auto setting failed'], while all other ...
CrimpOn
Feb 01, 2022Guru - Experienced User
MK2022 wrote:
2) The TV is able to connect to my mobile phone hotspot and to all previous WIFI equipment on the 5 GHz broadcast.
A) Unchecked 'enable 2.4 GHz' under 'enable AX'.
The TV appears to prefer a 5G WiFi connection when one is available (which the Orbi provides).
Doing anything to the 2.4G WiFi is unlikely to change the situation.
The KS7000 appears to date from 2016
This makes it extremely unlikely that this model will support 802.11ax on either WiFi frequency. Firmware updates have no impact on this because ax support is part of the actual WiFi 'chip' in the hardware.
Might try disabling ax support on the 5G WiFi.
or.... check in with the Samsung support options to see how Samsung customers are dealing with 802.11ax.
ekhalil
Feb 01, 2022Master
With TV I recommend to use WPS.
Follow the bellow steps to set up a WPS connection:
-Press the Home Button icon on your remote control.
-Select Settings > General > Network.
-Open Netwrok Settings > Network Type.
-Select Wireless > Wireless Connections.
-Scroll Down > press Use WPS.
-Press the SYNC button on Orbi node closest to the TV (router or satellite) to establish a connection.
-Once a successful connection is made, press ok.
- MK2022Feb 13, 2022Aspirant
Thanks, this solution worked temporarily, for a few days. Since the tv shows the same connectivity issues with the previous router (which has worked fine for months), then there must be something wrong with the tv (firmware). I will try contacting Samsung shortly.
- FURRYe38Feb 13, 2022Guru - Experienced User
You might give this a review aswell:
