MK2022
Feb 01, 2022Aspirant
Samsung TV [KS7000] can't connect to WIFI [ORBI RBK 752 - 2 pack mesh]
Last Saturday, purchased and installed ORBI RBK 752 2-pack mesh system. My Samsung TV KS7000 can't connect to the ORBI WIFI ['Wireless network disconnected. IP auto setting failed'], while all other ...
ekhalil
Feb 01, 2022Master
With TV I recommend to use WPS.
Follow the bellow steps to set up a WPS connection:
-Press the Home Button icon on your remote control.
-Select Settings > General > Network.
-Open Netwrok Settings > Network Type.
-Select Wireless > Wireless Connections.
-Scroll Down > press Use WPS.
-Press the SYNC button on Orbi node closest to the TV (router or satellite) to establish a connection.
-Once a successful connection is made, press ok.
MK2022
Feb 13, 2022Aspirant
Thanks, this solution worked temporarily, for a few days. Since the tv shows the same connectivity issues with the previous router (which has worked fine for months), then there must be something wrong with the tv (firmware). I will try contacting Samsung shortly.
- FURRYe38Feb 13, 2022Guru - Experienced User
You might give this a review aswell:
