PW20
Sep 23, 2021Initiate
Samsung TV unable to connect to wireless network
In the last week our Samsung tv has lost the ability to connect to our wireless network. We have a CM1200 cable modem (comcast) an RBR850 touter and 2 RBS850 satellites. We’ve rebooted all devices, tr...
Polzy
Oct 10, 2021Aspirant
Having the same problem also with a Samsung TV UA65KS9000W, was working fine on Wifi with Orbi 850S for the last 6 months but in the last 3 weeks it will no longer connect. It is not an issue with the wifi card on the TV as I have been able to successfully connect to a mobile hotspot. All things point back to the Orbi.
Factory Reset Orbi - initially worked, but once TV powered off the next day it stopped working and fails to get an IP address.
Tried static IP - won't connect, and Orbi doesn't show the device
Tried Resetting Smart Hub on the TV - no change
Tried setting up a guest wi-fi on Orbi - no change
