kknox14
Jun 30, 2021Follower
satelite Ethernet cable connection speed
What speed should i get through the ethernet port on a satelite. 200 meg service Orbi AX4200
Thanks
Netgear has set up a community forum specifically for the Orbi AX (WiFi 6) products. Most of the people who watch that forum are more likely to have experience with Orbi AX and know how to work it better than those of us who follow this "general Orbi" forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Orbi-AX/bd-p/en-home-orbi-axThank you.
Depends on what you connect to the RBS and it's design and support for speed and distances between the RBR and RBS.
