CharlyPy
Jun 20, 2021Aspirant
satelite Orbi RBK852 disconnecting
Hello, I'm in trouble with a router and a satellite RBK852 I am using them since 2 years and since 2months i have many trouble. I am in router mode just behind my FAI. I have an ethernet link ...
Jun 20, 2021Guru - Experienced User
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite
What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
- CharlyPyJul 12, 2021Aspirant
Hello Furry,
I use the version: V3.2.18.1
My network provider is Free with the freebox revolution
I have a have of 60m2 on 2 floors
I began by use a patch panel :
From my box to my orbi router (in router mode) and from my router to my patch panel and to my orbi satellite (in ethernet).
As it was not working, i try to put 8m without ethernet between my router and my satellite but it didn't work also.
This is my channel settings
Region Europe 2.4G Channel Auto (13) 2.4G Wireless mode: Up to 1147 Mbps 5G Channel 36 + 40(P) + 44 + 48 5G Wireless mode: Up to 2402 Mbps 4 others wifi received.
I will try to set the channel manually but i have the feeling that the trouble come from the IP assignation
And i have something maybe strange. When i see the hardware the orbi application say that i use a RBR850 with a RBS850. Anyway i still have the backhaul status of my satellite disconnected
- FURRYe38Jul 12, 2021Guru - Experienced User
So when you have the RBS near the RBR and connected the RBS isn't sycning fully?
Does the RBS connect to the RBR while in same room with the RBS using the sync buttons in back of the RBS and RBR?
Would need to make sure the FW on the RBS is the same version as the RBR as well...
Wire connect 1 PC to the back of the RBS. Factory reset the RBS, wait about 5 minutes. The PC will get a IP address from the satellite. The RBS will be 192.168.1.250. Use this IP address in a web browser to log in to the satellites web page. Log in as admin and password. Check the RBS web page for FW version. If it's not the same, Use the satellites web page FW update feature to select the FW update file that was unpacked from the .zip file downloaded from here: https://www.netgear.com/support/product/rbs850.aspx#download
- CharlyPyJul 13, 2021Aspirant
Yes there are not syncing. Yesterday i reset factory both.
i have no problem with the router but i can't link the satellite to the router and i can see sometime a wifi orbi coming from the satellite.
I will try your proposal to reset the satelite.
