CharlyPy
Jun 20, 2021Aspirant
satelite Orbi RBK852 disconnecting
Hello, I'm in trouble with a router and a satellite RBK852 I am using them since 2 years and since 2months i have many trouble. I am in router mode just behind my FAI. I have an ethernet link ...
CharlyPy
Jul 12, 2021Aspirant
And i have something maybe strange. When i see the hardware the orbi application say that i use a RBR850 with a RBS850. Anyway i still have the backhaul status of my satellite disconnected
Jul 12, 2021Guru - Experienced User
What is the distance between the router and satellite(s)?
So when you have the RBS near the RBR and connected the RBS isn't sycning fully?
Does the RBS connect to the RBR while in same room with the RBS using the sync buttons in back of the RBS and RBR?
Would need to make sure the FW on the RBS is the same version as the RBR as well...
Wire connect 1 PC to the back of the RBS. Factory reset the RBS, wait about 5 minutes. The PC will get a IP address from the satellite. The RBS will be 192.168.1.250. Use this IP address in a web browser to log in to the satellites web page. Log in as admin and password. Check the RBS web page for FW version. If it's not the same, Use the satellites web page FW update feature to select the FW update file that was unpacked from the .zip file downloaded from here: https://www.netgear.com/support/product/rbs850.aspx#download
- CharlyPyJul 13, 2021Aspirant
Yes there are not syncing. Yesterday i reset factory both.
i have no problem with the router but i can't link the satellite to the router and i can see sometime a wifi orbi coming from the satellite.
I will try your proposal to reset the satelite.
- FURRYe38Jul 13, 2021Guru - Experienced User
Let us know...
