z8
Dec 14, 2020Guide
Satelitte Confusion
Hi, I've got a RBR850 setup with two satellites. I had some issues yesterday so needed to restart everything. Things are now running but I have some lingering issues. On the 'home' screen of ...
z8
Dec 14, 2020Guide
It shows me two connected satellites - one without much info and with a default IP. Neither has the option to remove it.
I rebooted .1.168 and I can now access the web interface. The problem wasn't a password, the satellite GUI had become unresponsive.
Powering off .1.168 showed the 'upstairs satellite' as disconnected, but the .1.250 stayed in the GUI.
The other one, even after rebooting, seems to be connected and passing data ... but is not showing in the .1.1 GUI.
You can't access .1.250
Chuck_M
Dec 14, 2020Mentor
I had exactly the same issue... a factory reset resolved it.
