JaggleX25-_
Feb 10, 2025Follower
Satellite Alternately Blinking red and white
Writing for help regarding Orbi AX4200 WiFi 6 High Performance Router (RBR750)
Recently one of the satellites for this product began alternately blinking red and white. It doesn't appear that the WiFi coverage is affected so I have rebooted the entire product (router and both satellites) multiple times but the blinking persists. Any idea what the problem might be with this issue . . . and how I might fix it???
Thank you.
1 Reply
Is this in the front LED area of the RBS?
What FW is loaded on the RBR and all RBS?
Has a power off for 1 minute then back ON with the ISP modem and router and satellites been performed since last update? Try this with the RBS in same room as the RBR. 10 feet away from the RBR.
Turn off and unplug modem.
Turn on computers and rest of network.How many RBS are deployed?
What is the distance between the router 📡 and satellite(s)🛰️? 30 feet or more is recommended in between RBR 📡 and RBS 🛰️ to begin with depending upon building materials when wired or wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 🛰
