NGUser9999
May 13, 2024Aspirant
Satellite can't connect in AP mode on wired backhaul via ISP router
Hi Gang, my satellite is not connecting via an ethernet backhaul when I had it all set up and working without the ISP router, but wanted to get my orbi up out of the basement. Figured I would put...
NGUser9999
May 15, 2024Aspirant
Got it, yeah I have one cable running from the g100 router’s LAN port to the WAN port on the orbi router, and then just a second cable running from another of the G1100’s LAN port to the satellite. Shucks, thought that might work.
Seems like the easiest is to buy another satellite and stick the base orbit back in the basement and the g1100 in the trash.
Thanks for the comments, appreciate the guidance.
CrimpOn
May 15, 2024Guru - Experienced User
Yes, this is the most obvious and straight-forward solution. With the Orbi in the basement, satellites upstairs can be connected to it with the existing Ethernet cables.
