ferozar
Sep 21, 2022Guide
Satellite doesn't connect behind switch
Hi!! I have rbk753. I want to connect the farthest satellite by ethernet backhaul behind a switch...I have outages and want to improve my connection. When I connect the satellite directly to the r...
- Sep 23, 2022
Fixed!!
Add the solution:
The main issue was having a computer connected on wired and wireless at the same time.
This causes a loop inside my network.My Switch when detecting a loop disables the port for admin mode so that backhaul is not functional, though the normal traffic was ok...
Simply turn off the wifi on my computer then backhaul started to run correctly.
Thanks all for your support
CrimpOn
Sep 21, 2022Guru - Experienced User
ferozar wrote:
When I connect the satellite directly to the router is fine. I can see "Wired" as "Connection Type". (With the same wires as when it does not work)
Is it correct to read the same wires as meaning that the satellite was working
- At the remote location,
- With the same Ethernet cable to a wall jack
- With the same Ethernet cable wiring from remote location to patch panel
- With the same Ethernet cable from the patch panel to the router
- And the only change is that the patch cable was moved from the router LAN port to a port on the GS108T switch?
