ferozar
Sep 21, 2022Guide
Satellite doesn't connect behind switch
Hi!! I have rbk753. I want to connect the farthest satellite by ethernet backhaul behind a switch...I have outages and want to improve my connection. When I connect the satellite directly to the r...
- Sep 23, 2022
Fixed!!
Add the solution:
The main issue was having a computer connected on wired and wireless at the same time.
This causes a loop inside my network.My Switch when detecting a loop disables the port for admin mode so that backhaul is not functional, though the normal traffic was ok...
Simply turn off the wifi on my computer then backhaul started to run correctly.
Thanks all for your support
Sep 21, 2022Guru - Experienced User
I would say to make things easier, get you one of the suggested non managed switches. You can keep the other one connected of course, just don't connect the RBS behind that one.
ferozar
Sep 23, 2022Guide
Fixed!!
Add the solution:
- FURRYe38Sep 23, 2022Guru - Experienced User
Glad you got it working. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
