Ajujdeorbiuser
Apr 24, 2024Aspirant
Satellite failed latest update
My satellite failed latest autoupdate and the device is now blinking red power led. What to do?
Apr 24, 2024Guru - Experienced User
Pressing the reset button in back for 15 seconds then release doesn't clear the RED LED in back?
Last resort would be to do a 30-30-30 reset on the RBS to see.
If this fails then the RBS probably needs to be replaced.
- AjujdeorbiuserApr 24, 2024AspirantHello Furry, thank you the reply.
I tried Tftp method using windows cmd and. Tftp64 software. Both method failed.
But i successfully recovered the satellite by using Nmrflash utility. I used latest V.31 to recover. My satellite now connected to router and network. My home devices are connecting to this satellite. However the version showing is still V.21. From Orbi app and web console. I checked for update and shows no new update. My other device at v.31 and this one is still on v.21. Why is it like this? I am afraid to manually update. If the firmware again corrupted, ?- FURRYe38Apr 24, 2024Guru - Experienced User
If you can get to the RBS that has v.21 on it and access it web page, then manually update to v.31 by downloading the RBS FW file and sending the .CHK file to the RBS web page.
- AjujdeorbiuserApr 25, 2024Aspirant
Are you suggesting this method or other.?
1. Connect this satellite to laptop via LAN and access the satellite console page using its IP and upload the firmware?
or
2. Connect to router via LAN cable and using router console page and update this satellite alone manually.
Another doubt, why my the router is not showing update for this satellite which checking using orbi app or web console.?
